Like the title says or something similar. The TC-3000 has to be the blank silver titanium cone with high roll surround. Here's what I have for trade, please e-mail me if you need any pics:
MTX Thunder 502 2ch. amp
Amplifier Type Dual Channel
Bridgable Bridgable
RMS Power at 4 Ohms 90 W x 2
RMS Power at 2 Ohms 180 W x 2
Performance
Frequency Response 20 Hz - 20000 Hz
Signal to Noise Ratio 110 dB
THD at Rated RMS Power 0.1 %
Crossover / Equalizer
Bass Boost With Bass Boost
Bass Boost Frequency 40 Hz
Low - Pass Frequency 40 Hz - 200 Hz
High - Pass Frequency 40 Hz - 200 Hz
Other Features
Input Voltage 12.5 volt
MOSFET Circuitry Yes
Dimensions
Width 12.6 in.
Depth 9.75 in.
Height 2.1 in.
Audio Control EQx
Dual-bandwidth Equalization with Crossover
6 Band, 1/2 Octave Bass EQ
7 Band, Octave Equalizer
Two-way 24dB/Octave Linkwitz-Riley Crossover
Programmable Frequency Match (PFM)
Subsonic Filter
Line and Speaker Level Inputs
Balanced Inputs
Input and Output Level Matching Controls
Boston Acoustic S60 Components (no grills)
Nominal Size
6-1/2" (165mm)
RMS Power Handling - 55w
Peak Power Handling - 150w
Frequency Response (±3dB)
58Hz-20kHz
Impedance - 4ohm
Sensitivity (1 watt (2.83v) at 1m) - 92dB
Mounting Depth - 2-1/2"
Prefab Dual 12" Sealed Enclosure (local pickup only)
Custom box for 3 12's common chambered and double baffled (local pickup only)
3 MB Quart RWE-304 12's
4ch. Power Acoustik amp A600-4HP (matches mono DB series amps)
RMS Power Output: 85 Watts x 4 @ 2 Ohms
Birdged Output: 600 Watts
Signal To Noise Ratio: 97 dB
Frequency Response: 10-30,000 Hz
Bass Boost: 0-18 dB
Built-In Crossovers: HP / LP
THD @ 4 Ohm RMS Power: 0.02 %
Low Level Input: No
Built in Cooling Fan: No
Bass Control Knob: No
Dimensions: 11.25 L x 11 W x 2.3 H
Phillips Harddrive DVD Recorder/Player BNIB only tooken out to test it.
Custom black felt pool table 8' x 4' custom built (obviously local pickup only) $700
Like new LG 160W Compact DVD Shelf System with USB Port
Model: LFU850
Gamecube games: Geist, Sims Bustin' Out, NBA 2k2, Madden 2004
Computer games- Lands of Lore Guardian of Destiny, Battlefield 1942, Medieval Total War, Iwo Jima, Morrowind The Elder Scrolls III Game of The Year Edition
Nice Corona Neon Bar Sign (REAL bar neon sign)
Kenneth Cole watch
Bridgable Bridgable
Performance
Other Features
Dimensions
Width 12.6 in.
Depth 9.75 in.
Height 2.1 in.
Audio Control EQx
Subsonic Filter
Balanced Inputs
Nominal Size
6-1/2" (165mm)
58Hz-20kHz
Impedance - 4ohm
Bass Boost: 0-18 dB
Low Level Input: No
Model: LFU850
Kenneth Cole watch
