i need the install manual today in next 45 min before i leave work so i can print it HERE and the vehcile specific install sheet from directtechs for a 1996 chevy impala ss
12 Volts red + ignition harness
Second 12 Volts
Starter yellow + ignition harness
Second Starter
Ignition pink + ignition harness
Second Ignition
Third Ignition
Accessory orange + ignition harness
Second Accessory
Third Accessory
Keysense
Data Bus wht to wht/blk(resistor), wht to pur/wh(reference) VATS ignition key cylinder
Can Bus High
Can Bus Low
Can Bus Sw
Power Lock lt. blue + drivers kick panel
Power Unlock white + drivers kick panel
Lock Motor gray dirvers door harness
Driver Unlock Motor tan drivers door harness
Passenger Unlock Motor tan passengers door harness
Parking Lights (-)
Parking Lights (+) brown or purple + headlight switch
Hazards
Turn Signal (Left)
Turn Signal (Right)
Headlight yellow + headlight switch
AutoLights
Reverse Light
Left Front Door Trigger white - underdash light
Right Front Door Trigger
Left Rear Door Trigger
Right Rear Door Trigger
Remote Start, Security, Keyless Entry, Accessories (Continued)
Item Wire Color Polarity Wire Location
Dome Supervision use door trigger
Trunk/Hatch Pin dk. green - low in drivers kick panel
Rear Glass Pin
Hood Pin
Trunk/Hatch Release black/white + at switch
Trunk Release Motor
Fuel Door Release
Power Sliding Door (Left)
Power Sliding Door (Right)
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Trunk Alarm Shunt
Tachometer red/black AC 4 pin plug below intake
Wait to Start
Neutral Safety
Clutch Pedal
Fuel Pump
Rear Defroster
Mirror Defroster
Left Front Heated Seat
Right Front Heated Seat
Speed Sense green/white 4 radio harness
Brake Wire white + at brake pedal switch
Parking Brake
Horn Trigger black - steering column
Wipers purple + L of steering column
Left Front Window (Up/Down) dk. blue - brown A at drivers door switch
Right Front Window (Up/Down) lt. blue - tan A at drivers door switch
Left Rear Window (Up/Down) dk. green - purple A at drivers door switch
Right Rear Window (Up/Down) lt. green - purple A at drivers door switch
