WTB Small footprint 2 channel amp
Shoot me a priceto 85757 and a length. I can't find size specs on it.
---------- Post added at 07:48 PM ---------- Previous post was at 07:47 PM ----------
Too long
NThT876m
C1RWWRdC
$75 shipped or make me an offer on it.. Will retest it before you actually send money as its been sitting up for a while..
specs
RMS Wattage at 2 Ohm x 2 Channels: 75
RMS Wattage at 4 Ohm Bridged x 1 Channel: 150
RMS Wattage at 4 Ohm x 2 Channels: 60
Peak Wattage at 2 Ohm x 2 Channels: 150
Peak Wattage at 4 Ohm Bridged x 1 Channel: 300
Peak Wattage at 4 Ohm x 2 Channels: 120
Stable down to: 2 Ohms
Active Crossover: Low-pass (LP) 50 - 200 Hz, High-pass (HP) 50 - 200 Hz, Full (AP)
Bass Remote Included: No
Channels: 2 Channel
Cooling Type: Heatsink
Design: Class A/B
Bass Boost: 0 - 18 dB
Power Ground: 8 Gauge
Recommended Amp Kit: 8 Gauge
Signal-to-Noise Ratio: >95dB, a-weighted, re: rated power
Dimensions (in): Length 10-1/4" x Width 9-5/8" x Height 2-1/8"
CEA-2006 Compliant: Yes
I'll have to measure to see if it can work. Issue is its going under my 3rd row, which is normally up and there is room. However, when it is down the seat is going to be on the amp. So no air circulating.
Ahhh... No idea how it runs cool or hot.. but when I test it out I'll let you know.. won't be till thursday as i'm going out of town for 2 days tomorrow.. but I will let you know.. also price is not set in stone at all..
ace_800
ace_800
Okinawa, Japan
audiobaun
