WTB: Small footprint 1000x1 @ 1 or 2 ohm
alxmlr789
6>5
Let's see what you got. I had my mind set on the PDX, but i can't justify to spend that amount of money on 1000 watts. //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
I'm looking to spend less than 300 bucks.
I have the perfect amp for you.I have the memphis 16-st1000d.it is only like 12'' long.I will measure it to make sure,but I know it is not more than 14'' long by 6'' wide.$200 shipped.
the pistures are in my for sale thread.is says 4 channel monster,memphis 1000d.lmk
That's a nice price on that RD that SPY has. Especially if it has warranty!
Not sure how small you need, AQ1200D has a small footprint.
Mmats amps are pretty small too, but might be a little more pricey.
if you looking for BNIB w/warranty check out the AQ 1200d, i just picked one up, and it goes for $249 shipped direct from AQ dimensions are 12.75"(L)x9.27"(W)x2.35"(H) I was looking for the exact same thing as you were last week, and these things are very efficient
MMAT pro audio 500.1wrms (UNDERRATED)
500 W RMS 1 Ohm Mono
Leading edge technology
Efficiencies over 90%
4 AWG battery inputs
Optimized for low impedance loads
Dual MOSFET power supplies in the HC models
24db low pass Linkwitz-Riley infinitely variable filter
Frequency Response(-3db) 10Hz to 230Hz
Signal to Noise Ratio -92db A weighted
Distortion@Rated Output
Damping Factor@100Hz >125
Input Sensitivity 150mV to 2.5Vrms
Idle Current 1 amp
Efficiency @ 1/3 power >72%
PM me if interested.
alxmlr789
6>5
alxmlr789
FL
kingkongjr
