WTB: small 2 channel, and tons of small wire
01 S 10
LOUD
Im looking to power a few sets of outdoor speakers, i only need about 100-200w per channel @ 2ohms. im trying to keep it around $50 shipped (can spend more for a great deal). does not have to be top end stuff.
also, i will need atleast 50' to 100' of 14awg wire (12awg would work too). i might just pick some up local unless someone might have both an amp and wire for a package price. let me know
thanks,
Cody
what size is it? id like to keep it under my seats (12" x 12" or so)
thanks
edit: any pics?
See JBL's site:
http://www.jbl.com/car/products/product_detail.aspx?prod=GTO75.2%20II&ser=GTS&cat=AMP
PIC! - and yes it is professionally painted, i also have its matching 301.1
what does the jensen do for power? is it small too?
it claims 220w on the amp, but i cant really find any specs on the web, maybe you would have better luck, i found some awhile back but now cant. i believe it does pretty close to what it claims though. And i know for a fact the mtx will do what you need, those amps were way underrated. Both are extremely small footprint. let me see if i can find my links to my threads real quick..
here is a pic of the jensen..
Jensen XA1120 2-CHANNEL Car Power Amplifier
2 CH: 2 x 55 Watts RMS (4ohms) 2 x 110 Watts peak
3 CH: 2 x 75 Watts RMS (4 ohms) 2 x 150 Watts peak + 1 x 150 Watts RMS Bridged (8 ohms) 1 x 300 Watts peak
2 CH: 2 x 83 Watts RMS (2ohms) 2 x 166 Watts peak
1 CH: Bridged 166 Watts RMS (4 ohms) 332 Watts peak
Power Rating
4-channel design bridgeble to 6-channel
Switchable low pass crossovers
MOSFET power supply for cooler, more stable operation
2 ohm stable operation for maximum efficiency
Bass Boost +6db 45Hz Circuit and thermal overload protection prevents amp failure
Variable input sensitivity for perfect match with car stereo
Floating ground inputs
Gold-plated low level inputs and screw terminal connections
Discrete bi-polar output transistors for maximum efficiency
On/off sensor turns amp on and off with car stereo
ok, thanks guys. im checking on craigslist and going to look local. all of those are good choices for me, ill let you know what im going to do.
anyone have any speaker wire to add in? to help save some on shipping it separately from somebody else..
thanks,
Cody
thanks,
Cody
how much wire you need?
01 S 10
LOUD
01 S 10
Central Florida
01 S 10
