WTB Service: Fiberglssers/Painters Needed
DB_DRAG_SPL
Stupidity is Contagious
I need a custom built control box built, because I have no time to do it. It will need to house (1) Single Din Cd Player, (1) Master Power Switch to turn on cd player & volt veters, (2) RF Volt Meters (I can make a template for the cutout if needed). The design of the enclosure will be up to you, go as crazy as you want with it, just remember it needs to be handheld and functional. It MUST have an access to the inside somewhere on the enclosure, wether it be screw on or hinge type.
I would really like someone who can do BOTH glass work and final painting and has some decent skill with a paint gun/airbrush, but it is optional, I can have it done locally if needed as long as the finished piece is up to quality standards and finish.
I would REALLY like to see some photos of prospective builders previous work (build logs always a plus). Once I have decided on a builder, then I will go over some of the smaller details with them.
Volt meters being used.
Circuit board is 3"x4" and the display is 1.5"x3.5" centered on the board
id like it done to, just need it to fit my SPG and have a spot for my amp on it to fit my firebird 97... wanted it to be blue..
the place here was asking for like 2 grand.. i was like u can **** my left one
Wish I was in WV id help ya out np
No need to be in WV, it needs to be a handheld unit so it should be fairly cheap/easy for anyone to ship.
I KNOW someone is up to the task. Here's the chance to show off your skills and make some $$$ at the same time.
For a handheld unit or for a full fiberglass podium?
DB_DRAG_SPL
DB_DRAG_SPL
WV
Adamsauve
