looking for say 10 ring terminals that can run 1/0 and true 1/0 like kicker and knu, the hole size on the ring needs to be big as possible since the terminals i have are made with big screws and the ones i have wont work they are 3/8
You can do that too, I'm just saying you can drill them out some to save some coin //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifok thanks i might take back the battery terminals and get ones with a smaller screw
I'm not sure exactly how you are putting on your terminals, but here is how I put mine on.yep i drilled them out and it works however i still need some more
whats the best brand out there i have a problem getting them to stay tight on the wire and can slide off sometimes its aggrivating how can i fix that use solder or wat
Ah, see you hate the split terminals, I hate the unsplit terminals. Haha //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif. It's just personal preference though, I prefer the split one cause using the method described above I can get them to close ending much more round instead of looking completely flat and whatnot. It just looks cleaner in my opinion.ok well i ordered audiopipe and the kicker wire would fit but i had to open them a lil wider with a screw driver
and then i just used a pair of big pliers to squeeze down the terminal on the wire and i think thats my problem plus i hate terminals with a split in the middle so i ordered these that are solid
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWNX:IT&item=300250771282
bought ten of 1/0 and 4 guage connectors
and what is flux i am unsure what you mean by that
In soldering of metals, flux serves a threefold purpose: it removes oxidation from the surfaces to be soldered, it seals out air thus preventing further oxidation, and by facilitating amalgamation improves wetting characteristics of the liquid solder.
