WTB Orion RGC-1
You can build your own with some 18G speaker
wire, a 10K Ohm potentiometer,
a 1/8" stereo miniplug, a small knob and some
soldering.
You will solder the negative lead (shield) from
the 1/8" mini plug to the
negative speaker wire and then
solder the negative speaker wire at the other end
to the center post on the
pot. The positive terminal on the 1/8" mini plug
(center pin) will then be
soldered to the positive speaker wire. Now
depending on your pot the speaker
wire will go to either the left or right
whichever corresponds with a
reduction of gain in the circuit. Test it by
plugging in the 1/8" miniplug
to the port on the amp then while holding the
positive wire to the left post
turn the pot clockwise, you are looking for an
increase in volume from the
amp. If that corresponds to a decrease in volume
then you will need to use
the right terminal on the pot. (left / right is
determined by holding the
pot with the terminals vertical at the top)
When finished plug the miniplug into the
amplifier and turn the remote gain
knob to minimum. Turn the amplifier gain to the
max setting. Now the remote
knob will control the gain of the amplifier.
HeatSeeker
Oh lawds
HeatSeeker
Tampa, FL
HeatSeeker
