WTB: Orion adjustable crossover module(s) for oldschool Amp
There was an SLF-1 module for sale on eBay but the guy wants insane money ($65) for it. It would be cheaper to use an Orion 200CRX and feed the amp via the DIN plug or just buy a cheap outboard crossover instead.
Try therobotunderground on eBay and see if he has any available.
I notices the same, $65. Think he wants $40 for 1 adjustable crossover card.
My manual shows 1 card capable of 12db and 80hz.
And 2 cards capable of 24db and 63hz.
Would i be ok with just one card pushing subs(2 12`s)?
I have the capability of running my subs with a 24db per octave slope with my Alpine 7998 but prefer 12db since it is a more gradual roll off. Since with an 80Hz cutoff I am still reaching out to about 92Hz and downward.
It will sound good with a single SLF-1 and a bypass board, Orion also made a DVX-2 crossover for the pop top series amps as well. It is the equivalent of having a 200 CRX network installed in your amp and also has the ability to run 24db/octave but is kind of confusing to adjust. TristanRules has some I think but the single SLF-1 and bypass will be perfectly fine.
The XTR-2150 is a killer amp, I had one before I got lucky enough to find a GSX-300 which is a hot rodded XTR-2150 in a 24kt gold chassis.
I looked up "robotunderground" on Ebay and indeed he had what i needed,
an SPF-1 card for $33 shipped.
Seems like my best solution for now so i ordered one.
You`ve been a great help and i thank you much
bobbymac
bobbymac
Gulfport, MS
bobbymac
