WTB: new amp
What are you looking to spend? I have an Alpine MRD-M1005. Does 700w@4 ohms and about 1100w@2ohms. Is not 1 ohm stable. Looking for $230 shipped. Comes with original packaging, manual, etc.
What's some prices, im really down to spend what ever... i just want somthing that will last, im tierd of messing with this stereo crap as much as i enjoy it, id just like to have some money to spend on other things... like stripers and cheap hotel rooms.
haha, i dont wanna spend over 3bills. That being top dollar.
ALSO i want pics please.
here are some specs
300x1@4
600x1@2
1200x1 @ 1
effeciency: 75%
S4a
--Note: This amp has crossovers adjustable enough for active setups. I DO NOT reccomend this vs. a HU with active setup. I a/b'd them and there is a difference...Having said that, if you do not have an active capable HU and wanted to venture into it, this may be a great option, as it does sound good, just not as good.
Series
S
Input Sensitivity
0.2V - 8V
Variable High Pass Filter
20 Hz - 500 Hz (200 - 5 kHz) at 24dB/Oct
Subsonic Filter
Variable Low Pass Filter
50 Hz - 500 Hz (500 - 5 kHz) at 24dB/Oct
Clipping Display
LED
Tested Voltage
14.4V
Tested THD
1%
Model
S4
Power at 4 ohm
100W x 2ch + 200W x 2ch
Power at 2 ohm
150W x 2ch + 300W x 2ch
Damping Factor
>550 @ 2 ohm
Power at 1 ohm
175W x 2ch + 350W x 2ch
Power at 4 ohm Mono
300W x 1ch + 600W x 1ch
Power at 3 ohm Mono
350W x 1ch + 700W x 1ch
Max Dynamic Power
400W x 1ch + 800W x 1ch
Efficiency thru Output
64%
Dimensions - mm
390 L x 235 W x 53.4 H
Dimensions - inches
15.35 L x 9.25 W x 2.1 H
Signal to Noise
95 dB
Shipping Weight
16 lbs
can grab some pics for you tomorrow since car is in the garage.
elite08
www.SoundAdviceTexas.com
elite08
Houston, TX ( Alvin ) [281]
Team H&K
