WTB Lots of stuff!!! Subs, comps, wire, damping...
mendon mafia
`94 caprice, 15" Fi BTL
Im looking for a decent ACTIVE comp set. my amp is 90x4@4ohms so its gotta be able to take that daily. budget is $300
Im also looking for a pair of 12's that will take abuse and get LOUD. SPL is all the matters. cant require more than 2.5 cubes each tho. Must be louder than SX's and take 1600 daily each. $600 for the pair MAXIMUM.
Looking for Roll of speaker wire 16 gauge 100 ft. preferably knukonceptz, the twisted stuff but it dosnt really matter. CHEAP
Looking for 0/1 power wire. short lenghts (under 4') CHEAP
im also looking for a lot of fatmat, rammat, dynamat, etc i need a lot of it (enough for a large luxury sedan, doors, trunk and floor) and it need to be extremely sticky the stuff from home depot did not stick to any part i wanted it to, it stuck to itself and anything i didnt want it to like glue tho lol. CHEAP
silly question' date=' but, did you clean with carb cleaner or anything before you applied the deadener? was it cold out?[/quote']
i cleaned with rubbing alcohol i did it during the summer and left the material in the sun to heat up very hot. i also tried using a hair drier, and i also tried applying when it was not hot but about 75 degrees. none of these allowed the material to stick unless it was held there for over 5 minutes with pressure.
black on black good look on the wiring but the comps are too much money very good quality though,
oldschool can i see some pics?
mendon mafia
mendon mafia
Cocoa Beach, FL
skierxx5556
