WTB- In need of a
SomeguyinPDX
GunHappy
I'm In need of a few things:
2-Dist. Blocks that have 2-1/0 inputs and 1/0 and 4ga outputs
1-200amp circuit breaker or fuse holder that accepts 1/0 in and out
Post or PM me with whatcha got and what ya want for it.
stinger has the plug in volt meter spg something anyways you can get it off ebay for 14.99 free ship under a different name brand(I guess the orig manufacturer) I cut mine up and put it in the dash but this will give you an idea of the size and color. If you want I will dig up the ad number.
Man that's a clean looking install for your volt meter. I don't care if it's Stinger, the one you got is perfect! If it's not to much trouble please post or PM me the add # and I'll order mine right away.
iSimple HubvoltVM Car Digital Volt Meter USB Charger 12V Plug ................type this into the search bar only one result should come up and if you search
STINGER SGP12 DIGITAL VOLTAGE METER USB CHARGER 12 VOLT PLUG BATTERY MONITOR you will see they are the exact same thing.
iSimple HubvoltVM Car Digital Volt Meter USB Charger 12V Plug ................type this into the search bar only one result should come up and if you search STINGER SGP12 DIGITAL VOLTAGE METER USB CHARGER 12 VOLT PLUG BATTERY MONITOR you will see they are the exact same thing.
Thanks, Just ordered one.
SomeguyinPDX
GunHappy
SomeguyinPDX
Portland, Or
SomeguyinPDX
