S shaggy 10+ year member Junior Member Rating: 0% 0 0 0 13 0 central florida Sep 20, 2008 #1 I need an amp for 2 rockford fosgate p3's. There 4ohm 400w rms each. I would like the Hifoncis BXi 2608d but wilconsider anything. Click to read more...
I infamous_e46 5,000+ posts hArRy_DaNgLeRs Rating: 100% 50 0 0 26,366 257 California Sep 20, 2008 #2 if those subs are dual 4ohm and wire them for a 4ohm load then yeah but if you run it at 1ohm it will smash those subs pretty quickly
OP S shaggy 10+ year member Junior Member Rating: 0% 0 0 0 13 0 central florida Sep 20, 2008 Thread Starter #3 if those subs are dual 4ohm and wire them for a 4ohm load then yeah but if you run it at 1ohm it will smash those subs pretty quickly Click to expand... They are 4 ohm each but im a retard about all this so i was wondering is it better to run them 1,2,or 4 ohm
bad @SS chevy 10+ year member CarAudio.com Veteran Rating: 0% 0 0 0 2,861 0 ohio Sep 20, 2008 #4 You will be happier if you look for a 800-1000 watt amp @ 2 ohm...if they are single vc.s
OP S shaggy 10+ year member Junior Member Rating: 0% 0 0 0 13 0 central florida Sep 20, 2008 Thread Starter #5 You will be happier if you look for a 800-1000 watt amp @ 2 ohm...if they are single vc.s Click to expand... ok so would the hifonics BXi1208d be good? Its 900 watts at 2 ohms, 1 channel
dirtbagz89 10+ year member dirtyTHIRTY Rating: 100% 1 0 0 210 1 Buffalo, New York, United States Sep 20, 2008 #6 I have the 1608D model I'm trying to sell...only an hour of use on it. 1100 at 2 ohms
