WTB/ getting rid of Orion 2500d
My second battery was grounded to the chassis, that was the wire that came out of the battery which caused it to run DC power because my amp was straight grounded from the battery which isnt good
Well I'm sorry about the amp troubles, but running a ground from the batteries ground to the amp's ground is in-theory the 'best' available ground... //content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif
keep the amp, get a nice 200-250amp alt that idles around 100-150, they aren't too expensive, and you'll be set... that amp draws a lot of current but also puts out helacious power when fed correctly
Try hooking your ride up with jumper cables to someone elses ride if you get more watts or seems to be louder upgrade your alt!! //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif I know with mine, I hooked my old lady's car up to my car and it had a huge difference. So if I get an invite to finals im going to upgrade the alt but for time being my 83 amp alt is gettin the job done. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I need a amp thats going to push sum raw *** power to sum subs, Orion 2500d was OK but i felt it didnt do its job like i thought it would. So im in a the market to find an amp thats real good and has at least 2000 watts. help me out
I thought 2500d's do ~2700rms @1ohm?
937DYTBOI
TL>you
937DYTBOI
Dayton,Ohio
Lance3187
