Sold WTB: full system $350-400 max. (subs&amp)
Warrior
WI
Hi, I am new here but not to selling and buying things. I found this forum from my car club, ASOG. I am looking to buy a system for my 1997 Dodge Avenger. I am currently selling some items on ebay and my reserve is met so I will have the money for system, just whenever the payments gets here.
This is what im looking for:
2 10"s or 12"s in an enclosure
1 Amp to push both the subs
I want to get a decent deal anyways....i dont wanna go over $350 really, but I might go to $400. Let me know, thanks.
Also, I would like to use PayPal to pay for it because I can pay people alot quicker with that and the seller does not have to wait for the check to come in the mail. Thanks.
i got an e12kd2 in a 1.7 cu. ft ported box tuned to 40hz...or i can put it in a 1.2 cu. ft sealed box...and a kicker zr240 to push it...or maybe 3 10" mtx 4000's....let me know
Originally posted by Warrior Hi, I am new here but not to selling and buying things. I found this forum from my car club, ASOG. I am looking to buy a system for my 1997 Dodge Avenger. I am currently selling some items on ebay and my reserve is met so I will have the money for system, just whenever the payments gets here.
look into:
http://www.edesignaudio.com K series
http://www.respl.com SE series....don't pay attention to msrp price...about half the price
http://www.adireaudio.com shiva
if u were willing to go with 2 10" or 12" k's and a profile ca1200. That would be a great setup. OR, what type of sound are u looking for...spl or SQ...maybe look into a good single sub setup...like an elemental design O series and a jbl600.1 ! but, look around...and let us know what type of sound ur looking for. peace
NG
Hey guys im currently into a deal with this guy for 2 10" pioneer premier subs and premier amp. I'll probally get it for $350. Is that a good price? I think its a great price...
Subwoofers:
2 Pioneer Premier 10"
Model: TS-W1041DVC
Specs:
10" Premier VCCS PRO Component Subwoofer
Nickel Coated Foamed IMPP (Injection Molded Polypropylene) Rigilite™ Composite Cone Woofer
Aluminum Insert for Increased Cone Rigidity
Dual-Layer Urethane Surround
Direct Bobbin Mounted VCCS (Voice Coil Cooling System)
Conex Damper with Damper Ring
Lead Wires Integrated into Damper for High Reliability and Improved Power Transfer
Projected Pole Yoke with Vented Pole
High-Energy Ferrite Magnet with Bumped Back Plate
Low-Q Design for use in Small Sealed Box (0.6 cubic foot recommended)
Dual Voice Coil (2x4W ) Design for Increased System Flexibility
800 Watts Max Music Power
400 Watts Nominal Power Handling
Frequency Response: 18-2,500Hz
Sensitivity (Efficiency): 86dB (1W/1m)
2Ohm or 8Ohm Rated
Amp:
Pioneer Premier PRS-X720
Specs:
Specifications
Continuous Power (20Hz-20kHz, 0.04% THD)
2 ch: (4 Ohm) 100Wx2
2 ch: (2 Ohm) 200Wx2
1 ch: (4 Ohm) 400Wx1
Maximum Power (EIAJ)
2 ch: (4 Ohm) 250Wx2
1 ch: (4 Ohm) 750Wx1
Frequency Response: 10Hz - 50kHz (0,-1dB)
Total Harmonic Distortion:
Signal-to-Noise Ratio: >105dB (IHF-A Weighted, at 1kHz)
Dimensions: 10-3/8" x 2-1/2" x 13-5/8"
Features:
Bridgeable 1/2/3 Channel Capability
PWM Regulated MOSFET Power Supply
2 Ohm (4 Ohm mono) Optimized MOSFET Output Section
Balanced Isolator Input Circuit
Oversized Gold-Plated Screw-Type Power/Ground Terminals
Gold-Plated Screw-Type Speaker Terminals
Gold-Plated RCA Inputs
Gold-Plated RCA Outputs (Full Range)
Hi-Volt Input Level Control (400mV-6.5V)
Variable Crossover: 50-120Hz, -12dB/oct. (LPF/HPF)
Variable Bass Boost (40-120Hz, 0 to +18dB)
Subsonic Filter (15Hz, -18dB/Oct.)
Premier Power Certification Sheet
Premier Two-Year Warranty
Warrior
Warrior
WI
Warrior
