WTB: Cmass SS82 or other 8"
Mount them meaning? What the box is going to look like? I only have room for two under the passenger side i calculated a box that should have about 1 to 1.2 ft. might be able to get a little bit more.
the CMs would be perfect then.
which way are you going to face the subs
At the seat i am pretty sure just will have to make some sides to keep the subs from hitting the seat.
you shouldnt have to.
if you did have to just get some thick washers and lift the rear seat using them. the bolts should be plenty long to lift it 1/8 to 1/4 inch
Alright yea it shouldn't be that big of a problem if it even is one. Thanks for all the help This is a very welcoming site. I am usually on Tundrasoultions.com but not really much for audio over there so far this one has been great.
You got a pm
You got a pm
there are times you will get a ton of help here if you ask the right thing
other times there are some if you dont ask the right thing you will get shitt on from time to time.
the easiest way to make it work if its to tight with the CMs if you get em is use the washers like i suggested.
that way you have no worries about hitting the seat of wood digging into it
xctrack
xctrack
Tulsa
xctrack
