Brand new with warranty, Fusion 3 way 6x9's and 5 1/4's
Encounter 6x9" 3-Way Speakers
Balanced Motor Structure
Designed for efficiency in sound delivery, featuring a highly charged motor assembly
Dynamic Response Butyl Surround
The high performance butyl rubber surround produces controlled cone movement ensuring solid, undistorted sound
Chemically Treated Cone
Green Invasion, high impact, chemically treated cone to resist moisture and other environmental threats
Sound Dispersing Tweeter Housing
The Encounter tweeter housing diffracts high frequency sound, expanding the sound stage
Polished Chrome Chassis
Solid basket chassis protected and detailed in chrome. Stunning sound, stunning looks.
Product Specifications
Max Power Rating (Watts): 260
RMS Power Rating (Watts): 75
Compliance (Cms): 497.3
Cone Area (Sd): 20.8
D.C. Coil Resistance (Re): 3.6
Electrical Q (Qes): 1.59
Force Factor (Bl): 3.805
Free Air Resonance (Fs): 50.1
Frequency Response: 47Hz - 22kHz
Impedance (Nominal): 2
Mechanical Excursion (mm): 12
Mechanical Q (Qms): 2.154
Sensitivity (dB) (1W/1M): 86
Total Loudspeaker Q (Qts): 0.915
Magnet Structure (Oz): 16.3
Encounter 5.25" 2-Way Speakers
Max Power Rating (Watts): 140
RMS Power Rating (Watts): 40
Compliance (Cms): 767.95
Cone Area (Sd): 8
Electrical Q (Qes): 1.047
Force Factor (Bl): 3.246
Free Air Resonance (Fs): 67
Frequency Response: 72Hz - 21kHz
Impedance (Nominal): 4
Mechanical Excursion (mm): 9
Mechanical Q (Qms): 2.592
Sensitivity (dB) (1W/1M): 87
Total Loudspeaker Q (Qts): 0.746
Magnet Structure (Oz): 8
Get both pair for $90.00 shipped to your door!!
