WTB: Big Battery
king ranch
Banned
i am going to be running a zx1500@2ohms and a zx850.4 for my comps so around 2200rms
i have big 3 in 1/0 and a 130amp alt and a gold duralast battery the specs are O.E. group size: 65 *** 875 cold cranking Amps (1000 cranking Amps)
currently have around 1200rms no big 3 and the duralast and 130amp alt and at idle its in the high 11's low 12's on bass notes
so i will have that as of now and looking to put a battery in the back and run pos and neg to the back battery
wat would be the best battery for the back that can keep up with the power
thanks
no i am pushing a zx850.4 and a zx1500.1 smart guy
btw the kicker manual says 140amp alt min and i have 130amp alt so putting a big batt in the back should take care of my problem correct
and dont need a 8400 looking for a hc2400 or 2000 or even a 1800 w/e i can get a away with in the back along with current electrical i have or maybe even a batcap2k not sure which one would be the way to go
wats the specs on them and with a 130amp alt big 3 done in 1/0 and just one in the back on 2200rms can it keep up or am i gonna need both one in front and back, or keep stock upfront and put both in the back
Internal resistance
5 Second Cranking 1050 Amps
Weight 57.3 lbs
Constant Discharge Capacity at 77 degrees to 10.50 Volts:
20 hour rate: 3.5A/70Ah
5 hour rate: 11.9A/59.5Ah
1/2 hour rate: 87.5A/43.75Ah
CCA: 875 Amps
DIMENSIONS
SPV70 6-7/8" H x 13-3/4" W x 6-1/2" D
(Add 5/8? to height for battery post)
General POWER Series Specifications:
Temperature Range: -15 to +50 C
Typical Cycle Life: 350 cycles @ 100% depth of discharge (10.5v)
Maximum Charging Voltage: 15 Volts (Cyclic Use) 13.8 Volts (Standby Use)
Calculator says you need a 1400 and that's it.
http://www.kinetikaudio.com/calc.asp
i have a deka 9a31 if you intrested $150 shipped
will it keep my amps running and give them enough power with current electrical i have
//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Take both if you like
will one work or will i need both and how much both shipped
king ranch
Banned
king ranch
fl
dcmcki
