mine? it depends, but it could work if you run the stock ground with one of the upgraded grounds in one of the inputs (not really that tough, but not everyone wants the hassle). the power side though :/. it would work tho if you used a ring for the factory power connections and put them on the bolt and did the alt to batt in one output and the run back to the amps in the other output
