Sold WTB: Amp $300
Number of Channels 1 - Mono
RMS Power (4 ohms) 400 watts x 1 chan.
RMS Power (2 ohms) 600 watts x 1 chan.
RMS Power (1 ohm) 1000 watts x 1 chan.
Bridged RMS Power Not Bridgeable
Peak Power Output 2000 watts approx.
Min. Impedance Unbridged 1 ohm
Min. Impedance Bridged Not Bridgeable
THD @ Rated RMS Power 0.02%
Speaker Level Inputs No
Amp Preamp Outputs Yes - 1 Pair
Built-in Crossover HP (20 - 100 Hz), LP (30 - 250 Hz)
High-Pass Crossover N/A
Low-Pass Crossover N/A
Subsonic Filter N/A
Signal-to-Noise Ratio 80 dB
Channel Separation N/A
Bass Boost 0 - 18dB
Bass/Gain Remote N/A
Fan Cooled No
Fuse Rating N/A
Warranty 1-year SE
I'll give ya a BNIB A2400DB for $300 //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif but it certainly isn't the best quality out there... should give you around 1500 @ 1ohm
I have a couple nice US Amps USA400 and USA400X 1999 versions(the good ones).. about as good of quality as you can get for near the price range but im looking for 350+shipping on each also have a Zapco AG1000 that im looking for 325 + shipping for... here are specs on the us amps if interested.... These ams were rated at 12v so they are vary under rated.... I had them sent to us amps last year when i purchased them for a nice tune up so both are freshened up and one is signed by the guy who designed the amp. Both are Black
USA-400:
2 x 200W @ 4 ohms
2 x 400W @ 2 ohms
2 x 600W @ 1 ohm
1 x 400W @ 8 ohms bridged
1 x 800W @ 4 ohms bridged
1 x 1200W @ 2 ohms bridged
USA-400X:
2 x 400W @ 4 ohms
2 x 750W @ 2 ohms
1 x 1500W @ 4 ohms bridged
THD @ 4 ohms:
S/N Ratio: 115dB
Damping Factor: >1000
Fuse: External 225A
Dimensions: 23.75" x 7.5" x 2.1" (60.3cm x 19cm x 5.3cm)
Weight: 17 lb. (7.7 kg.)
systembumping
systembumping
Athens, GA
jiggy2dmax
