WTB- AB500.1 and Ma Audio HK802SX
First line says:
4400 watt 2 channel HIGH CURRENT amplifier.
It will work for highs BUT if you are wanting a "Class A/B" amp this is not.I am just trying to inform you that it is not an A/B if that is what you need.
This amp is good cause it will run at low impeadances.Where as an A/B runs at 2-4 ohms.
But the S/N ratio is pretty poor for what you are needing.
First line says:
I had a Alphasonik High Current amp that was 3000W and played fine but I need more power. Maybe A/B term is not right, I am looking for an amp that can play high pass not monoblock
Deephitters Mag
Beast From Da East
Deephitters Mag
Brooklyn, NY
Deephitters Mag
