WTB a good pair of 6.5ich comps and a amp for them
I've got three amps.. depending on how little or how much you want to spend.. but heres what I've got.. $75 shipped for the Clarion.. make an offer on the Zapcos
Clarion 4/3/2 APA4162
Maximum Power Output 260w (65wx4)
Continous Average Power Output 160w (40x4 into 4ohms 20Hz-20kHz @ 0.08% THD
Typical 2-ohm Stereo 65wx4 @ 0.8% THD
Typical Bridged Power 120wx2 @ 0.8% THD
Bass Exterender Control 0-12dB
Adjustable 4-channel 50hz-200hz, 12dB/oct. High/Low Pass Crossover
Mixed-Mode Operation
Bridgable 4-, 3, or 2-Channel Operation
Pulse-Width Regulated MOSFET Power Supply
Zapco MODEL Z100S2
2 x 50w rms
Specs:
Power/Mode
130 watts @ 4 ohm Stereo .02% THD
190 watts @ 2 ohm Stereo .04% THD
190 watts @ 4 ohm Mono .04% THD
Frequency Response 20-20kHz
S/N Ratio 110dB
T.I.M. .002%
Seperation 65dB
Slew rate 40 V/uS
Damping Factor 300 @ 4 ohms
Input Sensitivity .25-2.5 volts
Power Requirements 22amps, max, @ 2 ohm
Fuse Internal, 30A
Minimum Load 2ohms Nominal Stereo, 4 ohms nominal mono
Idle Current .8A
Dimensions 10.25"x6"x2.25"
Zapco MODEL Z150S2
2 x 75w rms
Specs:
160 watts @ 4 ohm Stereo .02% THD
250 watts @ 2 ohm Stereo .005% THD
250 watts @ 4 ohm Mono .04% THD
S/N Ratio 110dB
T.I.M. .002%
Seperation 65dB
Slew rate 50 V/uS
Fuse Internal, 20A
Idle Current .85A
Dimensions 11.625"x6"x2.25"
AndrewHilbert
AndrewHilbert
Louisville
Mat Dope
