wtb a blown hifonics amp
i got an the older version of the brutus 1500
the amp turns on but nothin comes out of the speakers when it is hooked up
its under warrenty if you wanted to just send it in to get fixed, im just to lazy to call and get a number to send it in since i have no use for it
let me know if ur intrestead
well what is your price:)
price and specs! ill be back later tonight
No. OF CHANNELS: 2
OUTPUT (watts):RMS @ 4 Ohms 80x2
RMS @ 2 Ohms 130x2
RMS @ 4 Ohm Mono 260x1
T.H.D.: 0.02%
FREQ. RESPONSE (Hz): 10 - 30k
SIGNAL TO NOISE RATIO: >97dB
DAMPING FACTOR: >200
INPUT SENSITVITY: 0.5 - 4.0V
CROSOVER SLOPES: 12dB
CROSSOVER FREQUENCY: High-Pass(Hz) 50 - 600
Low-Pass(Hz) 50 - 150
SUBWOFFER EQ: 0 - 18dB 0
SUBWOOFER EQ FREQ. (Hz) : 40 - 120
DIMENSIONS (INCHES): 9.5x2.5x10.75
Fully regulated MOSFET power supplies
PWM circuitry
Tri-guard amplifier protection
IDI (Intelligent Distress Indicator) gives a visual indication of the amplifiers protection status
Platinum RCA inputs and outputs
Line Outputs
Bi-linear selectable crossovers for inputs and outputs (Hi/Full/Low)
Continuously variable high and low-pass crossovers
Variable subwoofer equalizer
Phase inversion switch (0 - 180)
OEM floating ground input
Platinum 4-gauge power connectors
Tri-mode operation
$30 shipped?
mike dressure
enthusiast
mike dressure
mt home-boise Idaho
mike dressure
