wtb a 21" cone
I think what this guy ment was that you are not half done with the build of your 21" sub onlyfrom what I can tell - looks like your doing good with your viechle build for the 18"
but the 21" build of the sub only - what do you have so far for that ?
well i have a basket,i bought a pyle pro 21 off of PE for $200,which is cheaper that getting just a basket from IA,its the exact same basket as the IA 21 and the exodus audio maelstrom 21,i also have a few different motors to choose from,so basically all i need is the soft parts and im in business.
what do you think you can do with the stock "pyle" 21 cone ?
carefully trim it away its dust cap with a fresh exacto blade - and gently cut around the coil to free the cone from the spiders and coil ....
then all you would have to do is find a way to cut out the surround with out damaging it.. maby re use the cone since you already got it.
you CAN have a cone with a smaller coil hole cut out to fit a larger coil in it.... not shure what size coil the pyle 21 has from pe tho.
what do you think you can do with the stock "pyle" 21 cone ?carefully trim it away its dust cap with a fresh exacto blade - and gently cut around the coil to free the cone from the spiders and coil ....
well i bought that pyle just for the basket because IA told me it was going to be $239.99 + shipping just for the basket,and pyle wants $199.87 for a whole sub so i went that route.
and you are right,i dont want to be stuck with just an IA motor,im trying to have some options.the pyle does have a 4" coil but its only like 1" long,its quite pathetic really:laugh:
You should definitely just save the cone from the pyle sub to save yourself the headache.
i have thought about that but its a pretty crappy cone,i mean its kind of thin and the surround dont leave alot of room for excursion.but i might just try it anyway.maybe use a very thin coat of resin or some carbon fiber or something to stiffen the cone,i dont know ill try something.
nu2spl
nu2spl
Lancaster, OH.
nu2spl
