Sold WTB, 600 rms amp @ 1 or 4 ohm
175 watts RMS x 2 at 4 ohms
350 watts RMS x 2 at 2 ohms
700 watts RMS x 1 at 4 ohms in bridged mode
stereo or bridged mono output
Tri-way capable (Tri-Way crossover required)
50-210 Hz high-pass/low-pass crossovers, 12 dB/octave
wired remote control included for fingertip control of Punch Bass (boosts bass 0-18 dB, centered at 45 Hz)
MOSFET power supply and output devices
MEHSA mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability
TOPAZ — noise-killing differential inputs that eliminate 80% of ground loop noise
*****•ana circuitry keeps preamp voltages low and signal paths simple for outstanding audio quality
NOMAD — advanced protection circuitry for "intelligent" shutdown protection
speaker- and preamp-level inputs
8-gauge power and ground connectors
60-amp fuse and fuse holder required for installation
dimensions: 18-3/8"W (14-7/8" without endcaps) x 2-7/16"H x 9-7/8"D
175 watts RMS x 2 at 4 ohms 350 watts RMS x 2 at 2 ohms
****...I think I'm just being dumb, but we're using my 2 12", and lookin for 300x2 atleast. Can I still wire the 2 and get enough. I'm not the greatest with wiriing scematics
yes with dual 4 ohm coils your final ohm load would be 1ohm or 4 ohm and this amp does the maximum power at 4 ohms bridged or you can wire each sub down to 2 ohm individually and run each channel at 2 ohm to get the 350x2@2ohms this would make them sound nice and it is underrated at least 50-100 watts....
yeah I was thinkin that...lmk see what he thinks. Is that the best you can do shipped to 48875?
da box king
da box king
Portland, MI
riogigalo
