As the title says, would like it @ 2 ohms
This is going to be powering a 15" Fi Q for the sister.
liez.....battery to frame/chassis, alt case to frame/chassis, and alt + to battery +.....you need to have a good run from alt to batt anywayyeah, I don't want to do any major eletrical upgrades to her car as her main battery is in the trunk, big 3 would be a bish!
how is alt to batt in that car different than batt to amp in any other car....explain!?I can upgrade the grounds easily, but it won't be cheap getting wire from front to back (alternator to battery) and no its not the same, because her battery is about 4 feet away from where the amps going to be placed. And the wires are already ran.
Why would you be looking into an amp that does 1300 rms ???????? as stated in your PMyeah, I don't want to do any major eletrical upgrades to her car as her main battery is in the trunk, big 3 would be a bish!
jeebus you are hard headed......the alt to amp run in a typical car is that long....how is 15" from alt to amp in some other car different than 15" from alt to batt in your car:furious:alt is in the front of the car, batt is in the rear.. that's a good 15 feet in her car.
batt to amp is only like 3-4 feet away.
anyways, bump
dont bother. For a slight fee Il do it for you. im not that far //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif (Madison)I wouldn't mind driving up to WI to give you a beating //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
We don't do that around here like you cheese heads //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
I don't know anyone gets their runs from their alts //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gifjeebus you are hard headed......the alt to amp run in a typical car is that long....how is 15" from alt to amp in some other car different than 15" from alt to batt in your car:furious:
