Sold Wtb 5 Ch Amp
Silvercoupex
Im looking for a good condition, good quality 5 channel amp. Im looking at the JL Audio 500.5 and it seems to be what Im looking for so Give me some options if you have one...
JL Audio 500.5 Features
100 rms @ 4ohms 1-2 channel
25rms @ 4ohms 3-4 channel
250rms @4ohms sub
I have a couple of 5 channel amps.... a Soundstream P880.5 that I bought new and used for a couple weeks and a DLS Ultimate A7 that I am currently using but is one helluva sweet amp if you are interested.
Elemental Designs has the Nine.5 on sale for $350 before they go out of production. They were around $500 or so when they first came out.
RMS Power @ 12.5v : Front Channels
4 x 100 @ 4Ohm @ 0.05%THD
4 x 55 @ 8Ohm @ 0.05%THD
4 x 175 @ 2Ohm @ 0.05%THD
2 x 350 @ 4Ohm @ 0.05%THD
RMS Power (Subwoofer Channel) @ 12.5v :
1 x 250w @ 4Ohm @ 0.09%THD
1 x 450w @ 2Ohm @ 0.09%THD
1 x 600w @ 1Ohm @ 0.09%THD
Looks like a nice choice for you, and you would have the extra power there if you wanted to upgrade.
Only draw back to them is that they're 25" long, that's why they're going out of production, not many people buy them due to size.
i got a big belle {the aluminum one}not the black one 500.00 firm!
75x4 @4 ohms 300x1@4
115x4@2ohms 600x1@2
1100x1@1
this amp is perfect no scratches at all!!!!!!!!!!!!!!!!!!!!
pics available
i have a soundstream van gogh vga 800.5 amp. 50x4 plus 200x1 at 4 ohms, 100x4 plus 400x1 at 2 ohms. when new it was the flagship line for soundstream, dealer cost on this beast was almost 400.00. in great shape, 275.00 shipped.
specs:
* 5-Channel Van Gogh Series
* RUBI™ (Rapid-Use Branched Impulse) proprietary power supply topology
* STACT™ (STabilized Apex Current Topology) Reduces power supply stress 50%
* Trident™ amplifier protection topology
* Ultra-Low ESR Capactiance Bank ensure rapid power delivery for dynamic peaks
* Hawkins Bass Control™ Proprietary bass equalization topology
* IDI™ (Intelligent Distress Indicator) gives visual indication of amplifier protection status
* Harmonic Bass Alignment™ produces tighter, more accurate bass
* Fully regularted MOSFET power supply
* Triple Darlington Output Circuitry
* BIP™ Bias Input Protection
* Rail Stabilization Protection Circuitry
* Bi-linear selectable two-way crossovers for amplifier and line outputs
* Continuously Variable High and Low Pass Crossovers
* Balanced Line Inputs for the Highest Level of Noise Rejection
* Platinum RCA Inputs and Outputs
* Platinum 2-gauge Power Connectors
* Tri-mode operation
* Damping Factor: > 500
* Input Sensitivity: 0.15-12.0 Volts
* Crossover Frequency: 30Hz - 4kHz (at 12dB)
* Dimensions: 11.2" x 2.6" x 19.7"
Amplifier Specifications:
* Number of Channels 5
* RMS Power (4 ohms) 50 watts x 4 ch, + 200 watts x 1 ch.
* RMS Power (2 ohms) 100 watts x 4 ch, + 400 watts x 1 ch.
* RMS Power (1 ohm) Not Stable
* Bridged RMS Power 200 watts x 2 ch, + 400 watts x 1 ch.
* Peak Power Output 1600 watts approx.
* Minimum Impedance Unbridged 2 ohms
* Minimum Impedance Bridged 4 ohms (2 ohms for the sub chan in bridged mode)
* THD at Rated RMS Power
* Speaker Level Inputs No
* Preamp Outputs Yes
* Built-in Crossover Yes (30Hz - 4kHz)
* Signal-to-Noise Ratio 115 dB
Silvercoupex
Silvercoupex
Montgomery,AL
RXZILLA
