wtb 5 ch amp
drpdmazda
pa
i am looking fora 5 channel amp for my wifes explorer. i currently have a 2 ch bridged to the 4 mids and a 2 ch for the sub. i am looking for an amp tat can do at least 50x4 and at least 400x1 for the sub. there are a few on ebay i was looking at but figured i would give it a shot here first, if anyone has one let me know, message me or post here with price, pics, condition and most importantly price, i am not looking to break the bank, but i also dont want anything garbage, i also have some stuff for sale that we could work a trade on possibly
thanks
jason
i need at least 400 watts rms for the sub, its a kicker L7 8" and rms is 400 so i dont want o dip much lower than its rms rating thanks though
Soundstream D'Artagnan 5.1 Amplifier . I bought and tested it and everything worked perfect. Comes in the original box. 400.00 plus shipping
D'Artagnan 5.1 RUBIT (Rapid-Use Branched Impulse) Proprietary power supply topology STACTT (STabilized Apex Current Topology) Reduces power supply stress by 50% Auto High CurrentT Matches the amplifier for virtually every load application ChassisinkT Transistors are located between circuit board and heatsink for optimal heat dissipation Variable Input level controls for exact input match to amplifier Continuously variable 24dB low-pass crossover (40Hz to 220Hz) Continuously variable 12dB high-pass crossover (50Hz to 200Hz) Hawkins Bass ControlT Proprietary bass equalization topology Harmonic Bass AlignmentT Produces tighter and more accurate bass reproduction Continuously variable subsonic filter (13Hz to 30Hz) TridentT amplifier protection topology IDIT (Intelligent Distress Indicator) gives visual conformation of protection status Balanced Line inputs for the highest level of noise rejection Platinum RCA input and output Platinum 4 gauge power inputs 10Hz - 30 kHz frequency response >100dB S/N ratio 0.02% THD 6 Channels RMS @ 4 ohm 65 x 5 + 200 x 1 RMS @ 2 ohm 100 x 5 + 400 x 1 RMS @ 1 ohm 500 x 1 (sub only) Dimensions: 19" x 11.5" x 2.25
drpdmazda
drpdmazda
pa
eatank
