wtb: 4, 5 or 6 channel amp
Powerbass ASA1100.5x $280 shipped
• 4 ohm Power : 75W x 4 + 250 x 1
• 2 ohm Power : 150W x 4 + 500 x 1
• 4 ohm Mono Power : 300W x 2 + 500 x 1
• Peak Power : 2200W
• Total Harmonic Distortion :
• Frequency Response : 20Hz - 22,000Hz
• S/N Ratio : >94 dB/W/M
• Damping Factor : >150
• Input Sensitivity : 0.5 - 4.0 volts
• Crossover Slope : 12 dB
• High-Pass Crossover Freq : 40Hz - 250Hz
• Low-Pass Crossover Freq : 40Hz - 250Hz
• Variable Subwoofer EQ : 0/+18 dB
• Subwoofer EQ Frequency : 40Hz
• Dimensions : 18.5 " x 9.3 " x 1.9"
• Dimensions : 470mm x 236mm x 48mm
ASA 700.5x $255 shipped
• 4 ohm Power : 50W x 4 + 200 x 1
• 2 ohm Power : 100W x 4 + 400 x 1
• 4 ohm Mono Power : 200W x 2 + 400 x 1
• Peak Power : 1400W
• Dimensions : 14.9 " x 9.3 " x 1.9 "
• Dimensions : 378.5mm x 236mm x 48mm
not really small, 25" long, but a sq power house. sub channel is 1 ohm stable and does 100x4 @ 4 ohm @ 12.5v //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif you want high quality, well this is it, does not get any better than this amp.
Height : 2.250"
Width : 10.250"
Length : 25.500"
RMS Power @ 12.5v : Front Channels
4 x 100 @ 4Ohm @ 0.05%THD
4 x 55 @ 8Ohm @ 0.05%THD
4 x 175 @ 2Ohm @ 0.05%THD
2 x 350 @ 4Ohm @ 0.05%THD
RMS Power (Subwoofer Channel) @ 12.5v :
1 x 250w @ 4Ohm @ 0.09%THD
1 x 450w @ 2Ohm @ 0.09%THD
1 x 600w @ 1Ohm @ 0.09%THD
http://www.caraudio.com/forum/showthread.php?t=426615
Miles0803
Banned
Miles0803
Sac city
na_rsx
