WTB: 3 way component set 8's or 10's pref
Here are some specs....
MIDRANGE SPEAKERS:
• Exclusive talc-impregnated mineral filled poly-composite cone
• Proprietary butyl rubber surround formulation
• High-grade cotton/poly blended flat progressive-roll spider
• Precision machined and matched motor assembly
• Chrome plated and bumped backplate
• +/- 2dB from 60Hz to 6000 Hz
TWEETER:
• 1" Silk/Cotton blended soft dome
• Neodymium magnet
• Ferro-fluid cooling
• +/- 1.5dB from 1000 Hz to 20,000 Hz
• Surface, flush, and angle mount hardware incuded
CROSSOVER:
• 12 dB asymmetrical 2nd Order crossover alignment
• Audiophile grade air core inductors and mylar capacitors
• 0/-3/-6 dB tweeter attenuation switch
• Optical illumination tweeter protection
• Impedance matching components
• Tweeter phase selection 0 degrees / 180 degrees
• Gold plated terminals
• Crossover chassis designed for easy surface or flush mounting
Component Set
• Impedance 4 Ohms
• Frequency Response 45-20K Hz
• Sensitivity 91.5 dB
• Power Handling 150 RMS / 225 Peak
f0ki187
f0ki187
Huntington Beach, CA
f0ki187
