Hey thanks bacon, I appreciate that. I was just returning to post the spec sheet but you beat me to it! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif It mostly improved off-axis response at frequencies above 3k and probably improved power handling a tiny bit since the coil was open to the air but I never tested that theory, they're not suited for abuse. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifHere's T/s on an unmodified Audax mid:
Znom 6 ohm
Re 4.84 ohm
Le@1kHz 0.40 mH
fs 118 Hz
Qms 2.21
Qes 0.67
Qts 0.51
Mms 2.52 g
Cms mm/N
Sd cm2
BL 3.69 N/A
Vas 0.93 ltrs
Xmax 1.6 mm peak
VC Ø 20 mm
Sensitivity 1W / 1m 85.4 dB
Nom. Power DIN 25 W
Net weight .30 kg
Interesting to see how the mod changes the specs/FR
Do you have a model number? I can't see pics.I have one pair of these left which I have not modified to receive phase plugs. They're are out of production and sound great. 6ohm! $55 shipped. PM me if you like them.
Depending on how those audax's work. Otherwise, I am in for the Xtreams.I have some Soundstream Xtreams $20.00 shipped and some Soundstream Edge lines for $30 shipped both are brand new.
