WTB 200 wrms 4 channel amp (50x4w)
$175 shipped
RMS Power measured at 12.5 Volts DC:
37.5 Watts x 4 into a 4 Ohm load with less than 0.1% Thd+N
75 Watts x 4 into a 2 Ohm load with less than 0.3% Thd+N
150 Watts bridged x 2 into a 4 Ohm load with less than 0.3% Thd+N
Dynamic Power (IHF-202 Std) measured at 14.4 Volts DC
85 Watts x 4 into a 4 Ohm load
140 Watts x 4 into a 2 Ohm load
280 Watts bridged x 2 into a 4 Ohm load
Signal to Noise Ratio:
> or = 110dB A-Weighted
Damping Factor:
>200
Frequency Response:
20Hz-20kHz±0.25dB
Thunder EQ:
Variable Bass Boost (0-18dB) centered at 40Hz
Crossover:
Variable 50Hz to 200Hz, 18dB/Octave, High Pass or Low Pass Configurable
Dimensions:
13" x 9" x 2" (33cm x 22.8cm x 5cm)
14-1/4" x 9" x 2" (36.2cm x 22.8cm x 5cm) Including IsoFeet(TM)
$175 shipped
Damping Factor:
>200
Frequency Response:
20Hz-20kHz±0.25dB
Thunder EQ:
Crossover:
Dimensions:
Awesome O/S amp there..Wish I never would have got rid of mine:cool:
greendragonslim
2ndStringCarAudioJunkie
greendragonslim
downtown
350zspl
