different color wires. if he doesn't care and he wants it all to be the same color then its his choice.Why Does it matter if he needs power and ground?
Because the polarity on the ground and power wire make a huge difference. You do not want to get them mixed up. I have all my wire tested by an independent laboratory to make sure I use the correct wire for grounds and the correct wire for power. You would be surprised at the extra DB's you get by using the correct wire. I once used ground wire for the power wire and it fried all the cone gel out of my subs.Why Does it matter if he needs power and ground?
Thank you for explaining it to him.different color wires. if he doesn't care and he wants it all to be the same color then its his choice.
