wtb 2 matching amps 1000 watts?
US Amps USA 1000x. Well over 1000w @ 4 ohms mono.
Well over 500 x 2 @ 2 ohms stereo. Amp is black in color.
$250 + shipping if interested. Can provide pics if needed.
thanks for the replies. i got an email for 2 JL 500/1's for $420 shipped. i might go through with that but ill let u guys know. thanks
#1-Mine will be half that price
#2-It is much easier to wire subs together than to seperate amps
#3-It is less money/wire/room to wire subs off one amp
#4-You will get more power this way
#1-Mine will be half that price#2-It is much easier to wire subs together than to seperate amps
u make good points. let me do a little research on your amp. its the one on your sig right? cant u post pics so i can see the condition ??
i have 2 RF Power 800.2 that i put to my brothers 2 type R's in a tcaab box, and we had stuff moving on the walls. LMK
how much shipped to 92833? can you post or send pics??
I've got an Alpine MRD-M1005... puts out just under 1100w@2 ohms. Are your subs dual 2 or dual 4 ohm? I used another one of these amps to run 2 Type R 10s and they wanged. Currently been running it to one Type X 10, which wanged as well. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif Looking for $240 shipped...
both my Type R's are dual 2 ohms. can you send pics to crbarnes7900@yahoo.com pls? i think my peak is 1000 and my rms is 500. wont it have a chance to blow with that set up??
Peak should be 1500w each iirc. I ran the exact same subs x2 on one of these amps and they did just fine. If you're running dual 2, you'll run them in series parallel for a 2 ohm load. Each VC should see ~260w max, or 520 per sub. Which is more than fine.
VtecDis
VtecDis
Fullerton, CA
brirat
