WTB: 2 - 4 channel amp for components
adio
THE STEREOTYPE FIGHTER!!!
ok fellas,
i need something with will do at least 160 watts x2 @4 ohms ( not overrated)
must have a variable bass boost ( i won't have subs for awhile and i'll be running these full range until then)
10/10 mechanically and at least 7/10 cosmetically
hp/lp/full preferable ( squeak explained to me the other day that all u have to do is turn the HP all the way down to acheive a "full range" setting. someone wanna re-explain this to me again?)
i may edited this tomoorow or add more stuff to it, but this is all for now.
Did my 9.2X not meet your needs?
extremely close. an ed tech told me that it has a "push button" bass boost and i know thatll introduce 2 much distortion for me. how do i know? well, i definitely know that i'll be using a bass boost until i get some subs. it's better to be able to control it on yourown instead of just pushing a button and thats all there is to it.
and why'd u have to write this response.......... you make me feel all bad and ish!!!
Sorry but I just wanted to check because I was going to feed my 6 month old w/ the money from this amp sale. I guess he will not get to eat again, poor little guy.//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I have a Concept CC-2502L, this is not a normal CC-2502 it is the L a much better design that was limited in production. It is rated at 250x2 @4ohm 1000x1 @4ohm bridged. I belive these amps are also 2ohm stable bridged.
4 25 amp fuses, variable bass boost, HP/LP/Full filters.
$165 shipped.
Memphis St2004. Does 50w x 4 at 4 ohms, 75w x 4 at 2 ohms, and 150w x 2 at 4 ohms bridged. $100 shipped. Memphis tends to underrate their amps a bit too, so it should be about perfect for you.
thanks all, but i ended up buying a damond d3400.4 offa ebay earlier. it was exatly what i needed. thank yous to kicker06 for massive help!! next, i'll be probably putting up a WTB for some subs
breastfeed!!!!!!!!
adio
adio
college park, ga
adio
