WTB: 12" SQ sub Dual 2ohm 800-1000 rms with box
snakey5138999
Looking for a nice SQ sub. It needs to be a dual 2 ohm so i can wire it to 1 ohm for my amp. Amp will be pushing 1000 watts+ rms, so anything around that for the sub is good. Looking for one with a box included, as the box i have is only a .65cu sealed box and wont work for many subs. I prefer sealed, as per the space i want to take up, but if the dimensions are right, ported will be fine. My budget is about $200 or so with shipping. What do you guys have!!???
---------- Post added at 12:55 PM ---------- Previous post was at 12:54 PM ----------
I will reglue that carpet on the side of the box
SQ and 1 ohm are not a match, for SQ you really never want to run your amp lower than 3 ohm, maybe 2 ohm if that amp has great DF.
I have an old autotec 1200x amp. Rated at 1000w at 1ohm, prob more like 1100-1200 tho. I had 2 old RE se 12's, but blew one and am currently running the single one at 2ohms. Suppose to be pushing 700rms at 2 ohms. The single one sounds like ish! probably over powering it as well. Gains at like 75%, boost down, filter at like 80hz.
I know i said SQ, but i just want something that will be a quality setup. I want to run 1 ohm to get full potential out of the amp. Im pretty much just looking for a quality budget setup if that isnt an oxymoron. Wire this sub to 1 ohm pushing 1100 watts, im hoping will do well. Opinions?
snakey5138999
snakey5138999
Schenectady, NY
p3bumpin
