Wtb 12" beastly subwoofer
I have a BNIB pair of SOundstream Reference R1-12's they still go for $389 each shipped on the net.
Dual 3" Flat Wire Wound Voice Coil
Copper Clad Aluminum Voice Coil Wire
Dual Layer Aluminum Voice Coil Former
All-In-One Discrete Mount Terminal
Tall Motor Gap for extended X-Max
Dual Large High Temp Ferrite Magnets
Integrated Aluminum Motor Heat Sink
Stamped Aluminum Cone and Dust Cap for Added Heat Dissipation.
Large Diameter Surround for Added Cone Surface Area
Dual Mirror Stacked Spiders with Integrated Tinsel Leads
Secondary Stamped Steel Basket for Easy Re-Coning
Basket: 2mm Stamp Steel Re-cone Frame.
Motor: Patent Pending D.U.F. (Dual Under hung Flux Plates).
Magnet: Dual 100oz ferrite magnet rings.
Heat Sink: Patent Pending Washer Aluminum Heat Sink.
Ventilation: Pole Piece Sliced to Release Heat and Pressure from under the voice oil.
Voice Coil: 3" Parallel Windings of Copper Clad Aluminum wire wrapped dual ayers of aluminum former
Spider: Dual Mirror Stacked NOMEX Spiders with integrated flat tinsel leads.
Diaphragm: Reinforced Stamped Aluminum Cone and Dust Cap.
Surround: Santoprene Rubber Surround.
Mounting Depth: 7.5"
Outer Diameter: 10.375"
Cutout Diameter: 11.125"
Driver Displacement: .15 cu.ft.
Voice Coil: 3"
Magnet Weight: 250 oz
Resonant Frequency: 26.795Hz
Looking for dd 9500 or 3500 motor
Corybrdmn
Corybrdmn
Dunkirk, Ny
Corybrdmn
