xtant 202m, has 12db lp modulator chip, used to run my 2 12wOs. Just take out the chip and then you can run your mids if you want to do that later. $95 shipped to your door. Pics if needed
@ 4 Ohms 2 X 50
@ 2 Ohms 2 X 100
@ 4 Ohms Bridged 1 X 200
Freq. Response: 5 to 50kHZ +/-1dB Distortion (THD): Signal to Noise Ratio: >100dB
Input Sensitivity: 40 dB of available sensitivity, adjustable in 10 dB steps.
100mV to 8.5 Volts (unbalanced source)100mV to 17 Volts (balanced source)
Regulated, PWM Operational
11 to 15 Volts
30 Amp fuse
