wtb 10" sub
They handle 1000 rms a piece
They are rated for 1k. They will handle 2k. AQ does the same as sundown and a lot of other reputable companies and underrate their equipment. XFL's are also rated for 1k but if you have the slightest clue about what you are doing when it comes to setting your equipment up, they will also handle 2k of clean power on music.
350 shipped. D2.8 Aluminum coil. 2200W will burn pretty much any voice coil if you're too soft to turn things down when it gets smelly.
Looking to buy a beefy 10 thatl handle 22000 rms and need to run it at 1 ohm. Will also consider motors that I can just build up. I have a 10" ab xfl that needs recone I could throw in plus cash if anyone's interested.
I've got a minty Funky Pup 10" $350 shipped. Pretty sure they handle up to 35k watts, so you should be good with 22k. Try running at .5 ohms if possible. All sales are final.
Corybrdmn
Corybrdmn
Dunkirk, Ny
Corybrdmn
slater
    Oct 4, 2025
1aespinoza
    Oct 4, 2025
