WTB 1/0 ring terminals
You could buy the tinned 2/0 crimp rings below for $00.68 each. You will need 2/0ga crimp rings for most 0ga audio wire. If you are using welding wire, use the same size of crimp ring as the wire.
Waytek Wire 2/0ga tinned crimp rings
You could buy the copper 2/0 crimp rings below for $00.66 each.
Waytek Wire 2/0ga copper crimp rings
I have used these crimp rings many times and they are very nice. Much better made than most audio crimp rings.
The only set back is that they have minimums. I believe it is either a quantity of 10 or $6, not sure.
TeZ
TeZ
Delavan, WI
TeZ
