would these two go 2gether?
It looks like that amp may be stable to two ohms and with the sub you show, you can only have 1 or 4 ohms. If you run it solo, it will be under powered and if you run two it will be greatly under powered. It will work. But you will need to set your gains properly and with the lack of power, you may not be happy with the output.
4runnercrazy
Mattchu
4runnercrazy
Danville,CA
4runnercrazy
