Wood Thickness
It really depends on the size of the cabinet. But even a large cabinet can be braced well if built out of 3/4" material. But, if you're using 3/4", be sure and laminate the baffle with two sheets. Even with one inch material, I'd want to laminate the baffle with ½" so it would be 1½" thick.
Birch will greatly reduce weight and allow you to increase thickness/layers and still reduce weight.
I also heard that birch sounds a lot better. I think my next box will definitely be birch. Is birch any weaker than regular MDF? Would it handle a HDC312 on 1600RMS?
clickclickw00t
clickclickw00t
United States
Buck
