i still put a lot of screws in my boxes... i feel safer and like to know the box is never coming apartliquid nails
when properly assembled, wood glue holds the box together, not screws.
x2Wood glue + screws. Screws hold it in place until the glue dries. But i feel alot safer with both.
I used to not believe the jman on this issue ... that is until I took two small, random-shaped leftover pieces of 3/4" MDF, glued just the one's 4" long edge and just slapped it on against the surface of the other, just set it down, without even using clamps ... 1 day later I could not snap them apart bare-handed. Just to finally get an idea of what it would take to break them apart, I had to set it on the floor and stomp on it, and finally that did it.liquid nails
I suppose screws might make you feel better, like the wood glue might dissolve if your box gets wet*, but the MDF will swell up and then fall apart when wet, too ... then ya got screws holding nothing!!i still put a lot of screws in my boxes... i feel safer and like to know the box is never coming apart
This won't happen if you drill holes the same size diameter as the shaft of the screws you're using, or even a tiny bit larger. This really only happens when the screw shaft is bigger than the hole, and therefore the screw's shaft is pushing outwards on the board.use lots of clamps and wood glue if you have awesome skills cutting wood perfectly.
dry assemble to make sure it all fits, glue, then clamp and your enclosure will surely never come apart.
personally, i use a few screws.
predrill holes for screws *ONLY EVERY 6 INCHES* any more, and you will actually lessen the strength of your enclosure by splitting the wood all the way down.
use high quality tite-bond no-drip wood glue on the seams, assemble and screw together (after you dry fit and pre-drill all the holes). its all about prepping your work before you finish. if you predrill\assemble before you start trying to glue then things will go much smoother in the end and you will have a better enclosure when you are finished.
DONT USE LIQUID NAILS! wood glue should do the trick quite nicely. if you have some small gaps in the box, you can use some liquid nails to seal the holes from the inside, or you can use silicone - whatever floats your boat. i use the little tubes of silicone personally.
have fun.
