wonderful. glue on brahma is defective (just imo).
d audio 450
Registered User
this happened to my friend 2x...his spider came off the frame, he had the sub replaced, then it happened again....and im unhappy to say that the spider on my brahma is slowly creeping off the frame in one part of the sub....comes up about a mm when i depress the cone slightly.
what should i do.....i was originally planning on selling it...but now what/
****it.
-pat
get it repaired again, identifying the problem at hand. When you get it, check to make sure the glue is 100%, and if in doubt, wait 24 hours while the sub is inverted on the floor. If the problem persists, go with another brand. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
this happened to my friend 2x...his spider came off the frame, he had the sub replaced, then it happened again....and im unhappy to say that the spider on my brahma is slowly creeping off the frame in one part of the sub....comes up about a mm when i depress the cone slightly.what should i do.....i was originally planning on selling it...but now what/
****it.
-pat
Call Adire (where did you puchase it from? Josh? Visionary?) ... see what they have to say. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
- Steve
I had the same problem with my Alpine Type R 12" after a year and a half of constant use. I just folded back the rubber surround and put some of the STRONGEST glues known to man. When it dried I turned that sucker all the way up and no problems since then its had about 3 months use from another friend and no problems.
I highly recomend against using other glues on it. From what I understand, they use special glues to build speakers. I would recomend contacting who you bought it from. It is definitely a warranty issue and will be resolved for you.
well...my dealer told me that dan (wiggins) told him to just tell me to use regular old super glue. i am surprised at this notion of telling me to use a normal household product. i emailed dan a little while ago, but no response im going to wait to talk to him before i do anything i cant undo...
thanks for the suggestions and all tho guys- definitley appreciate it
-pat
d audio 450
Registered User
d audio 450
Pa Philly area
Mark_ab
