wireing
caliece
hi i have a question i now have 4 kicker l5's and wont to know if i can i wire the ohm of the subs like this wire 2 of the l5's into 1ohm and the other two into 4ohm and put it together does anyone know if i can do this if so what would the ohm equal.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
mmmmkay //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
whats the coil config for each sub? 4 subs total correct?
what final load are you trying to get?
they are dvc 4 ohm subs and im trying to at least get it lower than 2 ohm without going below 1 ohm between that ohmage.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
sorry, .5 or 2ohms for j00....no way around it besides a transformer
chances are the actual dcr of the coils is below 4 ohm per though..so you'll probally be right where you want to be w/o knowing it..
ok i get what your saying thanks alot:veryhapp:
caliece
caliece
chicago il
caliece
