Will this work?
yousmeg
If i was to buy a JBL GTO-1202D 1200W 12" Sub:
12" 1200W peak subwoofer
Dual Voice coil design (dual 2-ohm, pre-wired as a 4-ohm sub)
Power Handling, RMS: 300 Watts
Power Handling, Peak: 1200 Watts
Frequency Response (±3dB): 28Hz - 450Hz
Sensitivity: 93dB
And a FLI Amp:
Fli 400S Car Amplifier
2-channel amplifier, bridgeable into single MONO channel for BASS operation
RMS Out (4ohm): 2 x 100W
Total Max Power: 400W
Signal to Noise Ratio: 100dB
Frequency Response: 30 - 20,000 Hz
Total Harmonic Distortion: 0.05%
Crossover Type: LP/HP/Flat
Bass Boost
Crossover Slope: 12 dB
Would the amp power the sub properly?
that amp will only do 240wrms@4ohm bridged....get something better and a little more powerful....but it will work. should sound decent but you could always throw more power at that sub
yousmeg
yousmeg
simwhere
mbrooky
