Will this work?
Angelus
I'm probably going to kick myself for this but I need some help.
I have two Kicker Comp 10" sub woofers(not much but they do the job I ask of them) from my old car, the speakers are just a little over 5 years old, amp's fried I need to get an Amp before I put them in, my new car
I have been told by the place that I bought them from I need a 350W-500W amp 4Ohms.
I'm working with a limited budget and wondering if this will work for my Car Audio needs.
http://www.amazon.com/Pioneer-GM-5300T-2-Channel-760-Watt-Amplifier/dp/B000LYCWME/ref=sr_1_1?ie=UTF8&s=electronics&qid=1233349100&sr=1-1
That amp is not going to work for you anyways. You say you need 350w-500w at 4 ohms(which is more expensive) and that amp only does:
* 2-channel car amplifier
* 125 watts RMS x 2 at 4 ohms (190 watts RMS x 2 at 2 ohms)
* 380 watts RMS x 1 in bridged mode (4-ohm stable in bridged mode)
* selectable low-pass filter (80 Hz, 12 dB per octave)
* selectable bass boost (0, 6, 12 dB at 50 Hz)
why wouldn't it work?? 380 is bigger than his minimum of 350
Angelus
Angelus
Central KY
krisfnbz
