Will This Kenwood Work?
Just found out it is a 2 ohm. Amp is 1,000 watts RMS x 1 at 2 ohms so I'm guessing it should be fine?
Anything else that will work and not super expensive?
It will work.
I would go another route personally. It sounds like you have a d2? So you need power at 1 or 4ohm.
A cheap budget option is a skar lp1000d.
It will work.
Cool yep d2. Dang I looked for the model you listed and can't find it, I think it might be discontinued. I'm finding the kenwood cheaper than the skar amps. Thanks for the help!
audiopipe 1300 $109 ebay 1k at 1 ohm.. precision power 1k 2 1 ohm $129 or so.. or since r is rated at 1k most guys here over power sub be cause of box rise and u set gain lower and have cleaner power (no bass boost) try this or skar 1500 $179 i think.. https://www.amazon.com/AudioPipe-APCL15001D-Power-Class-Amplifier/dp/B00BW54418/ref=sr_1_1?s=electronics&ie=UTF8&qid=1493173605&sr=1-1&keywords=audiopipe+1500 u would need 0 wire and big 3 under hood if running over 1k in most cases..
type Rs are dual voice coil so you can only wire to 4 ohms or 1 ohm not 2.
Sorry for the ignorance/confusion, so that amp won't work?
also that kenwood is like $159 on amazon
Yep. That is in my price range if it will work for the type r. Thanks for the link! I would definitely buy it if amazon didn't say it would take 1-2 months to ship. Maybe cause it's discontinued?
yeah I didn't look at that.. u can get the skar or ap 1500 (I may get ap soon $149)
MT523
MT523
CO
MT523
