Will RCA's touching each other cause a fuse to blow?
XaznKewLguyX
bloop
I just installed my CD7000 today. Well after we soldered all of my wires together we gave it a test run. it turned on and worked fine. After we finished installing everything my fuse inside the engine bay for cig lighter/radio/clock blew. I tried to replace it and it blew right after i put it in.
I was wondering if RCA's touch each other behind the head unit will it cause a fuse to blow? Don't know whats wrong with it yet i havent pulled my dash apart since we finished. it was late and i was frustrated.
it shouldnt, my RCA's are touching. That's werid, if any fuse blew it should've been the one on the +12 volt power wire on the head unit harness. Maybe just recheck the wiring.
But after we soldered everything we gave it a test and it worked fine. After I finished installing everything we put it in again and the fuse blew. Replaced it and it blew right when i tried to put it in.. I am hoping something is touching the cig lighter. I havent had time to pull it out yet.
a way to find out is take out the rcas and see if it still does it //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
XaznKewLguyX
bloop
XaznKewLguyX
SoCal
PatFitz9
