Will a CADENCE TX-A1000D push a Fi BL 12??
Switch0
Wondering if these two products would be compatible. I've also heard the Fi is underrated so should I push for more wattage? or just go with the suggested....thanks.//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
NEW Cadence DCA1000 Class D Competition Mono Block Amp - eBay (item 290426896383 end time Apr-26-10 20:00:00 PDT)
REFURB Cadence FXA1200D 1 Ohm 4800 Watt Mono Block Amp - eBay (item 290415346837 end time May-17-10 14:53:15 PDT)
better amp options for the bl both under rated
the txa is a power monster, it sucks it down, i have seen 1200 plus from it but its a class a/b so its not effecient and its huge, to be honest i can get you a solid audio f15d for 200 shippend bnib
Solid Audio F15D
1 x 800W @ 4 ohms
1 x 1150W @ 2 ohms
1 x 1500W @ 1 ohms
http://forum.realmofexcursion.com/gallery/showgallery.php?cat=1724
It would be fine, but the Bl can take a bit more. Honestly, I would stick to the SSD at that power level.
considering sundown since I've heard good things...I've seen people pushing 1500w into these subs. Considering doing the same.
NEW Cadence DCA1000 Class D Competition Mono Block Amp - eBay (item 290426896383 end time Apr-26-10 20:00:00 PDT)REFURB Cadence FXA1200D 1 Ohm 4800 Watt Mono Block Amp - eBay (item 290415346837 end time May-17-10 14:53:15 PDT)
Solid Audio F15D
1 x 800W @ 4 ohms
1 x 1150W @ 2 ohms
1 x 1500W @ 1 ohms
Solid Audio F15D - Amp Guts
The Daytona is a great amp. However the FXA doesnt do rated power either. The only Cadence amps that do rated are the TXA, Daytona, Ultrashock (A7 HC, Z series stuff) , and the ZRS series. I may be forgetting 1 or 2, but those are the good ones.
Solid Audio F15D
1 x 800W @ 4 ohms
1 x 1150W @ 2 ohms
1 x 1500W @ 1 ohms
The TXA-1000D is a class D, not a class A/B....but it still isn't the most efficient amp. I really liked mine when I had it.
OP look into the MB Quart DSC-1500.1D. It's a GREAT amp for the money. I've owned some of the amps you're considering... the TXA-1000D, SAE-1200D, and two SAZ-1500D's. The MB Quart is better than the Cadence and hangs with any of the Sundowns for MUCH cheaper. However, the SAZ-1500D will handle low ohm loads, tons of abuse, and has the best customer service.
I had that Cadence amp and upgraded to the SAE-1200D and I noticed a nice gain in output. If you can get the Cadence for super cheap, go for it. I think I sold mine to my buddy for like $150 or something about 6 months back.
TXA-1000D
is a class d call up roy at cadende he will tell you, thats the reason why it is 25 inches long, its a surfboard amp, great sq
Switch0
Switch0
Salina, Ks
mclerico83
